disable ip option loose-source-route
Description
Disables processing of the loose source route IP option in the IPv4 packet header.
Syntax Description
Default
Enabled.
Usage Guidelines
Disables the switch from forwarding IP packets with the IP option for loose source routing turned on. Packets with the loose-source-route option enabled are dropped by the switch.
The following example disables processing of the loose source route IP option:
# disable ip option loose-source-route
This command was removed in ExtremeXOS 30.1, and then re-introduced in ExtremeXOS 31.2.
Platform Availability
